AE500 screen shots
dapex
I have looked through the lead called OK lets see yours and I have been very impressed with the actual screen shots of you home cinema's. Does anyone have a screen shots specific the the ae500???? I am going to order one over the next month or so and I would love to see other people's picture quality etc???
G a f f e r
Here you go:
harrisuk
Howser.
Very Very impressive. I hope mine looks this good when it is properly setup. Couple of questions i f I may. I am guesiing you are using DVI for it to look this good ? Also
What DVD player are you using ?
What Leads are you using ?
What Screen are you using ?
Looks high def quality to me......
H
Howser
I am guessing you are using DVI for it to look this good
Yes I use a 7.5 metre Cobalt DVI cable.(big improvement over the Lindy DVI cable i was using,almost totally eliminated VB which was still rife with the Lindy cable)
DVD player is a HTPC with ffdshow and theatertek using Lanczos resize,dscaler sharpen,chroma Luma sharpen and gradual denoise.(sharpening filters are applied very sparingly)
Screen is a 60" wide DRH pulldown screen
harrisuk
Excellent thanks for the tips. Point taken on the dvi cable, I just got a cheapy to start with will definately sprink for a decent quality cable now.
I have got a dvd player with dvi out to be going on with. Will definately go the HTPC route at some point though.
