AE500 pic goes Bright Green! Help!
Discussion in 'Projectors, Screens & Video Processors' started by RX-8_chap, Jun 21, 2004.
  1. RX-8_chap
    RX-8_chap
    Kind of new to this projector scene, so forgive me if this a very obvious problem!
    Basically when I first switch on the PJ the picture displayed looks kind of like a green negative, if you see what I mean... It doesn't seem to matter what input I use (I'm not using the PC inputs at all) the problem is the same.
    When I switch inputs the picture displays fine, then fairly quickly reverts back to the evil green!
    after 10 - 20 mins it seems to settle down and doesn't do it anymore. Is there some kind of setting I'm missing, is this usual PJ behaviour, or should I be shouting at the supplier and/or Panasonic?
    Many thanks in advance for the help.
    P.S. Great forum, glad I stumbled across it!
  2. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Hi Mate
    I saw this last night on mine too, happened about 30 seconds after I switched it on - I then presses component button on the remote and then it was fine again !.....
    Have you managed to find out what it is ?
    Anyone else experienced this ?
  3. ptek
    ptek
    Certainly not a feature, is menu OSD affected ?, if thats OK, what inputs are you using , if OSD is affected also, then problem with unit, better still, can you take photo of the effect :)
  4. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    I'm going to try again tonight
    Only started happening on the last two occasions....
    I hate it when things like this happens...... The unit is very new actually...
    I don't use it very much
    PS. Will also take pic if i can....
