Quantcast
Ae500 Mia
higenbs1
Does anyone know on any sites that have got the AE-500 in stock at the moment. Have tried Discount Electrical, Ivojo and Komplett and all are out unconfirmed delivery. That will teach me for umming and aaahing for ages.
higenbs1
Cheers - Does this include Dead Pixel Check? - can't see from their website
higenbs1
Cheers- have just ordered. Very helpful. Assuming there are no problems with delivery, krishav highly recomended
Tell me it's going to be worth it - I have high expectations of this unit
Gillykid
I dont think it does - they are pretty decent tho, good for returns and very helpful (ask for John)
Ekko Star
Just ask Jon to check it for you before he sends it out. Simple, they are really good for that kind of thing.
higenbs1
Right, now for a mount. Was going to go with LMP, as they seem to be quite well constructed. My wall has got 10cm worth of coving at the top. Does this mean I will have to buy a 100mm mount, or is it best to get a bit more i.e. 150mm
