AE500 High/Low Lamp Power Issue
Discussion in 'Projectors, Screens & Video Processors' started by justinh, Dec 17, 2004.
  1. justinh
    justinh
    May 6, 2002
    113
    Slough
    +6
    I can't tell any difference when I change between high and low for the lamp power in the Options menu.
    Fan changes speed but I can't detect any brightness change at all.
    I assume this is a fault in my projector but I thought I would ask before going to all the hassle of getting Panasonic to investigate the problem.
    I used to have it set to low power and low fan speed and the lamp died after 300 hours so I am wondering whether it has got "stuck" on high lamp power and so then overheated.
    Thoughts?
  2. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,996
    Lockerbie, Scotland
    +909
    Hi there,
    I cannot comment directly on the AE500. I have the AE700 and when changing from Low lamp to High, the increase in brightness is barely noticable. Perhaps the same is true for your AE500 unless you have used in on High before and now notice a discernable difference.
    Regards
    Keith HUrst
  3. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    I only notice a very slight change in the brightness and the fan becomes a little noisier on my 500.
