AE500 Green blob removal, but which ribbon is the green one?
Discussion in 'Projectors, Screens & Video Processors' started by Argentofan, Nov 30, 2004.
  1. Argentofan
    Argentofan
    Nov 30, 2004
    521
    28
    +39
    Got a nasty green blob on my AE500, which I assume is a dust blob.
    I understand that its most likely going to be the green ribbon which needs blasting, but which one is it? Tried blasting all three, and it seems not to have worked...
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    If the dust blob is on the green lcd panel or green polarising filter are you sure it would be projecting a green blob ? :D
    Jeff :rtfm:
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Dust blobs normally do show as green I thought, I've not seen it said that the colour indicates the panel involved .. my limited experience of blobs were on the optics though.
  4. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    if you look carefully under the ribbons there usually a coloured dot indicating what pannel it is, a greenblob does indicated dust on the green pannel, i recently had a blue dust blob which took me 3 goes to shift, i ended up changing the air blaster to one i bought from jessops with the screw in dispensing nozzle, the air pressure on this seemed much stronger than the other can i used and it shifted the blob first time
  5. kidooneill
    kidooneill
    Oct 26, 2004
    199
    +19
    Chic, I like your avatar :thumbsup: :thumbsup: :thumbsup: :thumbsup:
  6. GoggleBoy
    GoggleBoy
    Hello,
    Just wondering how easy and safe is it to DIY the dust blobs from my AE500.
    I phoned panasoninc tech support and they said they would do the work under warranty however it would take 4-6 weeks to do it :suicide: Quite a long time to be without my beloved PJ.
  7. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    very easy to do and as long as your carefull panasonic wont know you have opened the unit, just take care that you dont invert the can of air or propellant may come out, its best to learn how to do it as you will probably get dust plobs more than once
