AE500 and Room light levels
B
b6b6
Can anyone who has an AE500 tell me what the picture is like under different room light conditions?
What I am trying to say is how dark does the room need to get an acceptable picture?
I looking to buy either an AE500 or Epson TW200. I prefer the Panasonic but am concerned that it wont be bright enough for under general living room conditions.
Any advice Please.
BadAss
"Acceptable" Is down to your own personal taste.
But as a rule, the less light reflected onto the screen the better.
If you don’t have dark walls to absorb the light bouncing off the screen you’ll seriously compromise your contrast and wash away all those black/semi black bits. Budget machines just don’t have the capacity to block out all the light to make a black look a true black and your screen is itching to put as much light in your face as possible no matter what the source.
So the simple answer is, if you’re thinking of using any lights in your room no matter how small, don't.
(GTV)Chris
with light leakage switch to high contrast mode on the picture settings on the handset. This helps a little.
I have thick curtains to mask out the light but it wasn't enough, so I created sheets of blackout material on simple frames that match the size of the windows that attach to removeable rubber plunger type hooks and hey presto - nice dark room :)
Chris
IMO a perfectly dark room is absolute must for ANY projector regardless of how high light output is on a given model.
Why?
Because your blacks will only be as dark as the ambient light around it allows. The darker the room the higher your constrast ratio and image 'punch'.
zoolap
Chris
Do you happen to have any pictures?
B
b6b6
Thanks everybody. I have decided to wait for the TW200 and get my curtains lined.
WeirdFish
A wise move. IMO any ambient light ruins the whole cinematic effect.
I have blackout roller blinds behind my wooden blinds. They work well but now I've had the PJ a while and the initial wow factor has lessened I need to run the edges of the blackouts in channels to stop daylight fully on bright days.
zoolap
That would be great. We will hopefully be having an extension built and I'm thinking about buying an AE500 to go in there. The room needs to allow for use as a bedroom as well so I want to put curtains in rather than blinds. So I'm thinking of using lined curtains.
The main worry for me is doing the drilling and mounting of screen. Attaching a ceiling mount seems too scary. I have thoughts of the ceiling collapsing or projector falling on someone's head. Anyone know av people in the Warwickshire area that would fit this. The nearby shops seem to have some low/higher end DLPs, but not pannys though I may look at someone like NexNix. Anyone know good vendors in Warwickshire that would supply AE500 with dead pixel check (I know there is sevenoakes in Birmingham [might be out of their delivery range], also Richer Sounds in Coventry [they don't do the pannys I think] ).
(GTV)Chris
Get a gyrolok one. I used special plaster screws from B&Q (heavy duty) drill the hole, size 6 drill, then push the casing in. Then position the mount and drill it all in...if its coming down, then so is the cieling...very safe.
My screen is electric, so when its up you don't really notice it.
If you do line the curtains be aware that if you hang them from a curtain pole there will be light leakage from the top gap.
This is why I made blackout frames for the windows that can be stored behind the sofa when not in use.
Good luck with it. Hope you find somewhere to demo it, that is the best way to do it as you can check before you buy.
Ta
Chris
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
