sean.pittaway
- Joined
- Apr 23, 2004
- Messages
- 83
- Reaction score
- 1
- Points
- 48
Just a quick post...
I thought i might have a go at tweeking my Ae500 and give a filter a go (a mate uses one on his ae300, not sure if it makes the picy better or worse so i might as well try it on mine and see).
Did a quick search on here so i wanted to check what i am after
Its a "55mm Hoya FLD filter" correct?
Also, wheres a good place to order one from?
Cheers for the help, Sean.
