AE300 Throw distance mistake on Projector-Central?
Discussion in 'Projectors, Screens & Video Processors' started by Dekim, Mar 25, 2003.
  1. Dekim
    Dekim
    Feb 9, 2002
    293
    Hi all,
    I have a quick question especially to those who already own the AE300.
    I am trying to work out the min screen width with the projector seated 11ft from the screen (my seating position will be approx 8-9 feet). I went onto projector-centrals distance calc program and at 11 ft it states 64-99" width. Surely the figure of 64" is incorrect as if I do it for the PT-L300U it states 79-99" Also the AE100 shows 78-98".
    Can anyone confirm that this is indeed a mistake showing 64" as minimum width at 11 feet away?
    Also if minimum width is actually 79" do you think this is too large if seated only 8ft away as I read 1.5X the screen width is recommended.
    Thanks for any comments
    Deks
