AE300 Setup - Should I worry about lipsync?
Discussion in 'Projectors, Screens & Video Processors' started by crawf1982, May 29, 2003.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    183
    East Midlands, UK
    +7
    I am planning a new home cinema room that will feature the AE300 PJ. Due to the layout of the room I am wondering whether I am going to encounter lipsync problems. Here are the main components in the system and how they will be connected up:
    HTPC (for DVD movie playback)
    Video - Connected directly to PJ via short DVI cable
    Audio - Connected to receiver via long coaxial digital cable
    NTL cable
    Video - RGB scart -> JS Tech RGB to component converter -> receiver -> PJ via long component cables
    Audio - connected to receiver via short phono cable
    Gamecube
    Video - connected directly to PJ via short VGA cable
    Audio - connected to receiver via long phono cable
    Panasonic DMR-E30
    Audio - connected to receiver via short optical cable
    Can anybody foresee any lipsync problems with the above?
    The receiver will be a Denon 1803.
    Thanks in advance,
    Dave
  2. ChrisNightingal
    ChrisNightingal
    Hi Dave,
    Well I have the AE300 connected to a Yamaha DSP-A1 amp via a 10m S-VHS cable and don't have any problems that I'm aware of. Whether this can be related to your situation, I'm not sure but I thought I would just mention it.
    Chris.
  3. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    The only component that your likely to get lip sync with is your HTPC. When I first set mine up properly with my 300 it had terrible sync problems, it just turned to be a software problem ... .
    Gamecube is fine , as is Xbox , for me anyway ...
