AE300 Pretty Dim
Discussion in 'Projectors, Screens & Video Processors' started by Julia, Aug 5, 2004.
  1. Julia
    Julia
    Hi Guys,
    I wonder if anyone had the same problem.
    I have not used my projector for a few months and yesterday when I switched it on it was strikingly dim. :mad:
    The image was gloomy and rather lifeless. The colours I knew were not there.Even on high lamp it did not make much difference (there's hardly any difference between high and low lamp now).
    I had a look at the lamp hours and it is under 600 hours (I did not have the time to use it much for the past year).
    I guess this means I need a new lamp already?! At under 600 hours? The cheapest price I found was £165 from PriceJapan (does anyone know a cheaper one?). To be honest I'm a little scared to even put it on now, as I have read about problems with bulbs exploding after a dim period.
    Any ideas on what I should do?
    Thanks,
    Julia
  2. El Indio
    El Indio
    Jan 1, 2003
    35
    AFAIK, the bulb looses brightness over usage time - bright one day and then dim the next shouldnt happen.
    The settings menu is usually displayed full brightness (regardless of settings), so is a good test. Make sure you are viewing in a pitch black room (the ambient light during the day is much brighter now its summer)
    Also, If the bulb is faulty then hopefully the bulb fault light would come on (if the pj has one). I would check your manual.
    Regards, El
  3. Julia
    Julia
    Hi El,
    Thanks for your help.
    I completely forgot to check for any faulty light as it's up there on the ceiling...
    AE700 looks nice. I'm thinking maybe to buy a new bulb for my AE300 and then sell it and buy a new AE700 in September when they come out :eek:).
    (I'm just joking!)
    Thanks,
    Julia
