ae300 or philips garbo
Discussion in 'Projectors, Screens & Video Processors' started by yamman, Apr 18, 2003.
  1. yamman
    yamman
    Hello,i am looking some advice on which pj to replace my tosh 42" projector tv.
    my room is only 10.5 ft long and i will be sitting 8.5 ft from screen.
    My local dealer recommends the philips garbo over the pany ae 300 but i feel with such a short room the pany would be a better choice (looking good balance between size of screen and picture quality).
    So, my questions are ...
    which would be a better choice and what size of screen would suit the room? (i will be looking for a fixed screen for better quality).
    p.s are these projectors easy to install for someone who knows the right end of a screwdriver to use?
    Any suggestions guys.
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Both are good projectors but aimed at slightly different markets.
    The Garbo (and Garbo Matchline) needs about 2 x screen width for the throw distance. ie, 7ft screen needs 14ft throw. The Panasonic uses a shorter throw lens, something like 1.5 x screen width.
    Regards
  3. xander
    xander
    Jul 1, 2002
    130
    New Zealand
    I saw a Garbo in a shop today (first time I've ever seen one) and I must say that I was quite impressed. It's not as popular as the Z1, AE300, AE200 and X1, but should actually be. It gave a very decent picture at around 2m wide. The blacks are probably better on the AE300 though.
