Ae300 help
Discussion in 'Projectors, Screens & Video Processors' started by SCAMP, Jan 28, 2003.
  1. SCAMP
    SCAMP
    Dec 2, 2002
    35
    After buying new A/V system including Plasma i am know looking to buy relatively inexpensive projector and screen.
    Think the AE300 will be right when available in UK.
    The room is 15 x 15.
    Could anybody please recommend a good ceiling mounted screen
    which suites viewing DVD's mainly wscreen and is electronically retracted when not in use plus what is optimal size of screen for the AE300?
    Thanks for any help and advice.
  2. Spacecat
    Spacecat
    Apr 1, 2001
    3,330
    London
    +951
    why dont you go to projector central and check out the THROW of the AE300 that will give you an idea of how big the picture is going to be from a set distance.
    The review also mentions screens that go well with it
