Quantcast
AE300 Ceiling Mount?
M
MikeKeal
Anyone know (for sure) whether the AE300 can be mounted using a ceiling mount designed for the AE100?
Also, does anyone have any experience with the Unicol (or any other) mounts?
Thanks...
StAnToN
hi m8
got an AE300 myself and mounted it using the Unicol gyrolock mount and the AE100E bracket for the unixol fits the AE300 perfectly m8 so im sure that any other mounts made for the AE100 will fit the AE300.
thanks
StAnToN
:D
