Ae200
Discussion in 'Projectors, Screens & Video Processors' started by phlashman, Apr 4, 2003.
  1. phlashman
    phlashman
    Hello,
    I'm pretty new to projectors and I have a few questions. I'm thinking of getting a Panasonic ae200. Has anyone seen one in action? whats it like hows the color?
    also is it worth going for the ae300 even though it's more expensive?
    thanks
  2. tonytigerrr
    tonytigerrr
    Dec 3, 2002
    92
    Merseyside, UK
    +3
    I received my AE300 yesterday and I can heartily recommend it as DVD images look superb.
    Personally if I was choosing and weighing up cost v quality, I wouldnt even consider the AE200. This product seems a little redundant, seeing as the Ae100s are so cheap now.
    If cost is the primary factor then get an AE100 (or a Sanyo Z1) as you can buy one for less than £800 - if quality is the driving factor and you can afford the extra then plump the the AE300, you wont be disappointed.
    As to whether the AE300 is worth it, Id say that at £1700ish, it is still VFM but not the absolute steal of the AE100 at £800 - its not twice as good, thats for sure!!!
  3. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    For £1300 I think the Z1 is better value. I've seen an ae100 running, and while they're OK, the Z1 is a big step forward.
    Also, as you can see from other threads on this forum, the ae100 may still have major reliability issues.
  4. rogeralpine
    rogeralpine
    Oct 28, 2002
    565
    16
    The AE200 is £1169 from BEdirect although the Z1 would demand a viewing as well and maybe can be had cheaper than £1300.
