AE200 Secret menus
S
stuartsjg
Hi, ive seen that there are menus availiable that are "secret" can anybody tell me how to access them as im curious?
Thanks,
Stuart.
G a f f e r
with the AE500 (should be similar to yours)
go into options menu.
highlight OSD item.
keep 'select' depressed until secret menu appears...
T
Truecelt
seems to work, but what do the various menues do , IE auto setup "special" etc
G a f f e r
the most important is the flicker menu.
go into it and change the values for each colour (using arrow keys) until you don't see the colour flicker. Do this after about 30mins of using the projector.
if you now play a disc, the imAGE shgould be more stable and generally look slightly better. People use this for reducing vertical banding but I've never seen that on my proj anyway.
To tell you the truth, I have absolutley no idea what the other menus do (apart from the self explanatory self check one that is :))
