Ae200---my Findings
Discussion in 'Projectors, Screens & Video Processors' started by dek1965, Oct 27, 2003.
  1. dek1965
    dek1965
    Jan 20, 2003
    380
    Heysham
    +5
    got a 200 a few days ago and been messing with variuos software/hardware.
    so here's my conclusions
    1st go
    ae200 connected to dvd player via component, projected onto wall (matt white)
    used attack of the clones 7ft wide image
    amazing picture
    next up sky via scart
    pretty good
    2nd go
    hooked it up to my spare pc
    xp1900
    512 ddr mem
    64mb geforce4 440
    8x dvd drive
    for this one i pixel mapped the pc using the ae100 settings i found on here
    projected onto a sheet of 6x4 matt white 2mm foamex that i "borrowed from work
    pc desktop looked ace, great fun surfing the web on a six foot browser
    used same dvd as b4 and powerdvd5
    nice picture but colours were washy
    next up windvd platinum
    superb picture, loads of options to play with , but limited stretching capabilities
    next theatertek
    f*cking awesome picture, good scaling ability, by far the best
    so to all u purists out there i recommend
    a hcpc running powerstrip & theatertek
    "probably the best picture in the world"
    while ure at it connect your soundcard up to your amp and you'll be buzzing
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    If you're using 1:1 pixel matching, then what's with the "stretching capabilities" of Windvd, or the "scaling" of Theatertek ? A little confusing.....................
    Sean G.
  3. dek1965
    dek1965
    Jan 20, 2003
    380
    Heysham
    +5
    all dvd's are not the same size, so u either have black borders on screen or you either stretch the picture to fit or u scale the picture to fit, means the same thing
  4. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    the ritz,
    I hope you are taking this in ;)
    Cap:smashin:
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Cap'n,
    Oh yes, indeed I am..........................
    dek/mumble...
    If you're using the software player to "stretch" a 2.35:1 image onto a 16:9 screen, then you're inevitably going to lose picture quality in one way or another - 2.35:1 movies are that shape for a reason........... it doesn't "have" to fill a 16:9 screen, and as well as quality degradation you're probably losing part of the image too. Kinda completely defeats the purpose of 1:1 pixel mapping imo............. normal approach is to mask the screen for different aspect ratios, not distort the image to fit - but it's a matter for your personal preference at the end of the day.
    Sean G.
  6. dek1965
    dek1965
    Jan 20, 2003
    380
    Heysham
    +5
    image looked excellent to me, after it was stretched, looked same qaulity b4 and after stretching (we'll to me it did).
    like you said it's all down to personnal taste, and i prefer to have a full screen
  7. citrac
    citrac
    Aug 5, 2003
    96
    Can anybody advise where my friend and I might see one of these operational in Glasgow or near? It sounds like it is a great projector for the price.
  8. dek1965
    dek1965
    Jan 20, 2003
    380
    Heysham
    +5
    try these
    BURGESS GIBSON LTD
    45 HIGH STREET
    DUNBLANE
    FK15 0EE
    tel: 01786 823176
    SHOP PANASONIC
    32 HIGH STREET
    PAISLEY
    PA1 2BZ
    tel: 0141 887 7025
  9. ani4ani
    ani4ani
    Nov 12, 2001
    2,007
    Belper, Derbyshire
    +179
    I agree about TheaterTek being awesome off a PC - do you own a copy of it, as I cannot find a trial [unlike the others] or have you found a site to d/l a trial. I d/l PowerDVD 5 last night and tried it and was very impressed.
  10. Sandman
    Sandman
    Nov 28, 2002
    3,123
    Glasgow
    +704
    Go to robert whyte on dumbarton road in glasgow
  11. Jonathan100
    Jonathan100
    Don't know about places in Glasgow but Burgess and Gibson have a nice setup in Dunblane. They have a PT-AE200, with 2.4m wide screen connected to DVD player / surround sound setup and also to sky. The shop@panasonic in stirling which has just opened shold have the 300 and possibly the 200 on display soon too.
  12. Goof
    Goof
    Oct 14, 2002
    760
    Scotland
    Exactly what I've done with my 200 and the results are very good :)
    Only thing that bothers me is the screendoor on the 200, thinking about getting a Hoya filter, not too sure if this will help the screendoor any though. Does it bother you Dek? That said, I think I may just be sitting about 2ft too close (all room allows atm).
  13. dek1965
    dek1965
    Jan 20, 2003
    380
    Heysham
    +5
    didn't really notice screendoor, have just got a new screen so i'll try it out on that, and like you i will be getting a hoya filter also
