AE200 issue: Grey circle in corner
Discussion in 'Projectors, Screens & Video Processors' started by tomacwhite, Nov 23, 2003.
  1. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Just been watching a flick on the projector, and I have noticed a small grey circle bottom left of the screen which appears when the projector is playing something very dark, or if it has no input on a certain mode (like AV1 mode but not having anything turned on if you know what I mean).
    I first thought it was light reflecting on the screen, but its not as when I move the projector, the circle moves with it. I tried cleaning the lens with a glasses cleaning cloth, but that hasnt helped.
    Any ideas?
    Thanks.
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Sounds like a dust blob in the optics - do a search here for "dust" for lots of other accounts; a diy solution has been related by many, using a can of compressed air, take care if you're adopting this to make sure that only air is coming out of the can, the propellant liquid will cause permanent damage. If it's not very noticeable, you could just ignore it.
    Sean G.
  3. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    How big is it? Sounds like it could be a 'dead pixel' if only a few mm's squared? :(
    Edit: Sean beat me to it :hiya:
    Think it's depending on the size of the grey spot.
  4. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Yeah its much bigger than a pixel. I have run service mode and its only viewable when its dark. And its a very small area.
    I'll try a search on the forum, thanks.
  5. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
    i had one just like yours but green in colour, it's a bit of dust, you can either----- open pj and clean panels (search on here for info b4 u try this)
    leave it if you can't see it when viewing movies
    btw i got a hoya filter and using this i cant see my blob anymore
  6. snocrash
    snocrash
    Dec 27, 2002
    103
    I got an AE300 - and reckon I've got the same issue...
    When in shutter-mode (black) you can see 2 or 3 areas (prob. about 20 pixels in diam.) which are just ever so slightly lighter than the surrounding area.
    What's strange is; when i run White, Red, Green, or Blue full screen it's absolutely undetectable. Maybe the dust is refocussing some light - which increases the light intensity in one area of the screen while showing black... buggered if I know, but dust is the only thing I can think of.
    I guess I might open up the 'ol AE300 :-( Are the screws special ? (Torx security screws or some sh*t ?)
    Another thing I might do is put on some very dark sunglasses and look into the projector... you reckon I'll be able to see anything ? :)
  7. snocrash
    snocrash
    Dec 27, 2002
    103
    I've read through a lot of people giving the three LCD panels a quick squirt to dislodge any nasties and it seems relatively effective.
    But; That would make sense for a "coloured" dust blob. i.e., a greenish, reddish, or blueish blob... I'm wondering if one has a plain grey blob it would indicate that the dust is somewhere 'after' the three panels are combined?
    Big question: Where the hell do you squirt compressed are if its not the panels ?
  8. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    I wouldnt bother opening the projector - my dust blob has burnt itself out after a day of heavy usage, sweet! :)
