AE100 vs HS1 ????
Discussion in 'Projectors, Screens & Video Processors' started by Walter mitty, Feb 7, 2002.
  1. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Well can any tell me which is best for picture? Any body got a link to the spec of the Ae 100. thanks
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,479
    Windsor
    +1,046
    in my personal opinion, the panasonic kicks the HS1's arse, big time.
    I found the panasonic to be much more pleasing to the eye. The Sony was a little fatiguing, even after only 15 minutes viewing.
  3. Guest
    Mr Mitty, or can I call you Walter?
    Try here for specs...
    http://www.panasonic.co.uk/nw/products/product.asp?c=PTAE100E
    The Panny has swung it for me on its short through, 5000h lamp life, quiet running, £140 replacement bulbs, 16:9 panel, price & no need for special leads or connection box (like SONY). Need I say more?
  4. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Thanks to you both, and yes walters ok by me
  5. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Awwwwwwwww Andrew (MEAT) that link won`t work???
  6. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    I can’t comment on the PANA AE100 but I have had the HS1 now for 3 months and I have yet to be disappointed in the picture or found that the picture gives me any fatigue.
    As pointed out the cables are expensive but I have another post on the go in this forum regarding the pin-outs to help people who want to make their own cables from the basic one supplied.
    You might also find not being able to mount the projector on the roof a problem (this is not for me but might be for you).
    If the roof mount is not a problem then I would seriously suggest you demo the HS1 and the AE100 and see what suits your eyes.
    Kev.
  7. richard plumb
    richard plumb
    Jan 27, 2002
    14,479
    Windsor
    +1,046
    I agree with you Kevin, people should definitely look at both of them. My opinion was that the panny was better, but thats just my eyes. No one should fork out that kind of money without having some idea of what they will get.
  8. Guest
    Yeah! It's on the Panny UK site which seems to have a very unreliable server! Seems to be working at the moment though!!
