AE100 to NTL Cable?
Discussion in 'Cable TV & Virgin Media TV' started by ramchipuk, Jul 10, 2003.
  1. ramchipuk
    ramchipuk
    I have just tried to run my NTL cable to my AE100 by mean of a scart to svideo converter and a 10M cable but i can only get the picture in b/w. Can anybody help? Are the better converters and leads available?
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,200
    Scotland
    +178
    I think you are trying to converting a composite video signal to s-video which will not work.
    Your options are:-
    1/ Run composite vid to composite vid
    2/ RGB to S-Vid convertor (cost around 50 - 75 quid
    3/ RGB to component convertor (cost around 150 quid)
    er.. I think that's it...
  3. bunkerbuster2
    bunkerbuster2
    The NTL box doesnt output S-video
    I have the same problem with projectors and NTl, I use an RGB-S-video convertor (not a bad picture)
  4. aarons
    aarons
    i am using scart to composite pictures fine.try it and see
  5. bunkerbuster2
    bunkerbuster2
    Everyone has a different opinion of "Fine"
    For me, the composite picture is "Awful"
    The Converted RGB-Svideo picture is "Passable"
    The problem for stems from the image being projected (ie exacarbating any image issues)
