AE100 to AE700
Discussion in 'Projectors, Screens & Video Processors' started by windfall, Oct 5, 2004.
  1. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hi Chaps
    I have been through some of the very exciting threads on the AE700 but havnt found the answer to a problem I am going to face which relates to the mounting bracket.
    I (as my sig suggests) have an AE100 (until tonight) with a mount, will the AE100 mount work with a AE700? Has anyone upgraded and used the same mount?
    If someone could help I would be greatful as I can sell the mount with the PJ.
    Tone
  2. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    not sure about the 700 but i have just gone from 100 to 500 and the footprint is the same. so the same brackt has been used. The 700 is a differnet case as you may know so im not sure... im not even sure why i posted a reply sorry to be of little help :blush:
  3. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Well thanks for the reply anyway!
    I may have to let the unicol mount go but wont get anywhere near the £200 I had to pay for it!
    Which is a P***er!
    Tone
  4. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Would you not be able to just get a new mounting plate?
  5. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Wish I was that smart..of course! I will contact unicol and find out if they do a mounting plate for the AE700!
    Thanks for the logical answer!
    Tone
