AE100 to AE300 upgrade
Discussion in 'Projectors, Screens & Video Processors' started by TimF, May 28, 2003.
  1. TimF
    TimF
    Anybody upgraded this way? - wondered about:
    1 Worthwhile improvements 100 - 300, and
    2 PJ positioning and if can get away with mounting PJ in same position (and on same unicol mount if poss!) - would save a lot of work.
    Timbo
  2. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    1. I'll tell you in a few days :D
    2. It has the same throw and mounting holes as the AE300 apparently so you should just be able to do a straight swap.
  3. ChrisNightingal
    ChrisNightingal
    Well I bought the Unicol PSU series ceiling mount and the mounting bracket was actually for the AE100 so I guess they must be the same. That's assuming that you have this type of mount.
    Apparently the "SmoothScreen" technology is worth it on the AE300 but I haven't seen an AE100 in action. Just got my AE300 recently.
    http://homepage.ntlworld.com/chris.nightingale1/ftvtp/ftvtpmainpage.htm
    Good luck with your decision though.
  4. Insp.Gadget
    Insp.Gadget
    Dec 4, 2002
    132
    South East
    +3
    Chris, is it just a problem with my mac or are the pictures on your web-site not working at the moment (all just show red x's)?
    Greg
  5. Kramer
    Kramer
    Problem your end - fine for me :smashin:
  6. TimF
    TimF
    Thanks Guys - I have the "Gyroloc" adjustable bracket from Unicol (with an AE 100 adapter plate)
    Chris - from your photo's it looks like your bracket is a different design (Looks good though!)
    Anymore thoughts appreciated re differences in quality etc (New AE300 now costs less than I paid for AE100 only 10 months ago!)
    No demo's available locally
    Timbo
  7. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Interesting thread....
    I have an AE100 and would love to know if it really is worth ditching it for an AE300.
    It would have to be a big improvement to be worth the added expense.
    It looks like the contrast ratio is much better.
    Chris
  8. ChrisNightingal
    ChrisNightingal
    Timf, I got my unicol ceiling mount from www.projected.co.uk and I'm pretty sure it was the "PSU" model with the bracket for hanging the pj inverted as opposed to the "cradle" mount
    As for the website, I think it's ok, I am updating it every so often with new piccies.
    Thanks,
    Chris
