AE100 - Switch off at power switch or Standby
Discussion in 'Projectors, Screens & Video Processors' started by itspman, Jul 3, 2002.
  1. itspman
    itspman
    What do most of you do ...
    Do you switch it off at the power switch when not in use or leave it in standby mode via the remote.
    I have had my Ae100 for about 4 months and have always left it in standby mode via the remote when not in use.
    Last weekend I was going to demonstrate the system to a friend of mine when the projector went bang when I tried to bring it out of standby.
    Thankfully I bought it from The panasonic shop in Watford and they agreed to swap it over straight away with no issues (now thats what I call service).
    My question is I would like to prolong the life of the new one and wondered what you other guys do in terms of powering on off etc.
    Thoughts would be welcomed
    Regards
    Adrian:)
  2. DVDcake
    DVDcake
    Jul 1, 2002
    471
    Invading Surrey UK
    +3
    standby seems to be the best bet for prolonging the life of the PJ unless you intend to leave it off for several days. Your machine probably blew up due to one of the faulty power supplies fitted to early machines. I belive another thread mentions this but can't remember where.:)
  3. Feersum enjinn
    Feersum enjinn
    How do I know if my machine is an early machine, or a newer version?
    Is there any way of telling if i have that problem to look forward too in the next 4 months :)
  4. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    "How do I know if my machine is an early machine, or a newer version"
    The date of manufacture is stamped underneath. Mine is jun 2002.
    BTW when mine is in standby mode it emits a sound? You have to put your ear close to be able to hear it. Its a high pitch sound the turns on and off about every second.
  5. Feersum enjinn
    Feersum enjinn
    I will check mine when i get home - any idea however what is classed as an early (possible problem) machine and what can be classed as a new machine form a date perspective?
    (dont know about that sound - sorry :-(
  6. DVDcake
    DVDcake
    Jul 1, 2002
    471
    Invading Surrey UK
    +3
    I think any PT-AE100 made on or after May 2002 should be ok.
  7. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    How does standby prolong the life of the bulb compared to switching off completely? I don't get it.
    I always switch it off completely after the fan has stopped.
    Tor Arne
  8. Glasswalker
    Glasswalker
    I think it is due to the surge of power that will go into the bulb when switched on rather than when it has been it standby. This in the long run could effect the lifetime of the bulb.
    If you get what I mean.
  9. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    I don't think you avoid the surge of power when you just power it up from standby. It will happen every time you wake it up too.
    That's my impression. :)
    Tor Arne
  10. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    I agree. I have a Toshiba and when I switch on the power it comes on in standby mode anyway so I see no difference to the bulb by leaving it in standby.
    I have used three projectors (two Hitachis and the Tosh) and all three made a very low humming noise when in standby mode (some one mentioned above that the AE100 makes a noise in standby mode also). If there is noise then the pj is "doing something" and if a machine is at work (no matter how insignifigantly) it must be shortening its life span. So I always switch off the power to my pj when it has gone to standby mode.
    I know that I'm talking really long term here and this would have nothing to do with machines dying after a few months.
    Regards
    Conor
  11. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    My Hitachi CP-X275W makes a slight buzzing sound when in standby.
    Tor Arne
  12. StJonno
    StJonno
    I posted this in a previous thread about the same subject
    I had a demo of this proj at the weekend, and if my memory serves me correctly (which it rarely does!) , the sequence for power up is:-
    1.Turn on switch at the back (two red LED's come on, PSU probably stabilising)
    2. One LED ges out the other turns green (?)
    3. Press 'Power' button on top of unit
    4. Lamp goes through startup routine
    My point is, either turning the unit on from the main switch, or turning on from standby shouldn't make any difference as before the lamp will power up, stages 1&2 above must have been completed, either when the projector was first powered up , or having been restarted from standby. The power consumption in standby is quoted as 0.7 watts, which makes me think the main PSU for the lamp is probably not powered up anyway, so I would be very suprised if either method of start up is any better or worse than the other. what do others think?
