AE100: Shutter Mode
Discussion in 'Projectors, Screens & Video Processors' started by donmc, Mar 5, 2003.
  1. donmc
    donmc
    Does the shutter mode on the AE100 actually help in prolonging the life of the bulb ?
    If I leave the PJ for 20 mins to check email I "feel" it's better to engage shutter mode rather than turn it off and on again 20 mins later. Am I right or wrong - what do others do?
    Don
  2. Kramer
    Kramer
    Shutter mode just blanks the LCD panels - doesn't affect the bulb in any way IIRC.
    So, to shutter or not to shutter. That is the question.
    It makes no odds ;)
    The HS10 however does have a functioning "sleep" option. Bulb powers down after 20 mins of no signal - handy!
    Yet another reason to upgrade to a HS10. Go on, you know you want one :clap:
  3. donmc
    donmc
    Leave it!!!:nono:
    Seriously, thanks for the feedback. I'm more than happy with my Panny for now. Perhaps when the HS10 drops to £799 I may consider it :smashin:
    Don
