AE100 Service menu, what do the options do
Discussion in 'Projectors, Screens & Video Processors' started by azzo, Jul 13, 2003.
  1. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Can somebody please tell me what the two options:
    Runtime PRT and Image Shif? (I think thats what it was called) do.
    Thanx
    Azzo.
  2. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,959
    38
    Scotland
    +22
    Bump ^
    I would like to Know this as well?
  3. mince bigalow
    mince bigalow
    hi, could you tell me how I could get into the service menu please?
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Bumpety bump :)
  5. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    You press OSD for 5+ seconds.
    Not much use in here, but you can check your lamp life
    and do a panel test to see any colour staining and dead pixels.
    Don't think you can harm the PJ in this menu.
    I have played with the limited options, not knowing what they do.
    Azzo.
  6. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    You need to have the Options menu selected when you hold down ENTER. Just noticed last night that if you highlight the Lamp Hours item in the options (I think) and hold down ENTER, the item goes RED and says (should have written this down) "Reset on Pwr Off" (or something like that) - suppose this must be the quick way to reset your lamp hours.
  7. bunkerbuster2
    bunkerbuster2
    It is indeed... says it in the manual too!
  8. Fsheehan
    Fsheehan
    Sep 6, 2002
    448
    Up North!
    +8
    Is the panel test called the "service menu", when selected produces a completely white screen?
    Just wanting to know if this is the right one or if there is another.
  9. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    There's a "Self Check" option, which displays lamp hours (for up to 3 bulbs you've had in) and number of times you've switched the PJ on. It also shows the internal temperatures (hopefully tells you they're OK) and tells you your fan(s) are working OK.
    When you've brought up the white screen through service mode, you can use the up/down/left/right arrows to toggle colour, and output pattern i.e. only alternate lines showing etc. This is what you can use to check for dead pixels / colour uniformity problems etc.
