AE100 scart rgb - vga with prog scan question ?
Discussion in 'Projectors, Screens & Video Processors' started by mcaw, Sep 24, 2003.
  1. mcaw
    mcaw
    Sep 1, 2003
    92
    The forums suggest that you cannot make a scart RGB - VGA cable for the Panasonic AE100 as it wont sync down to 15Hz ( The Vertical sync frequency. )
    But is this valid for a Prog Scan player?
    If a player is outputting Pscan is the Vertical sync frequency doubled, and therefore shouldn't the AE100 be able to detect it ?
    Is Prog scan output to Scart as well as component connection ?
    Does anybody understand what I'm saying ?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    prog scan is component only at moment
  3. mcaw
    mcaw
    Sep 1, 2003
    92
    Is RGB on the scart not component ?
    RGBHV into VGA is
    YPbPr is another form
    Am I missing something.
  4. Kramer
    Kramer
    Correct. Completely different.
  5. mcaw
    mcaw
    Sep 1, 2003
    92
    As I understand it.
    A component video signal is a video signal that is broken down into component parts.
    RGB is a component signal, the three seperate colour components.
    YPbPr is another version, where the luminance is removed form the red and blue channel, and is carried on the green.
    Now on DVD players Prog Scan is delivered down the YPbPr component outputs, but players with a VGA output are also delivering Prog Scan through the VGA connection.
    But what about Scart RGB ?
    Is it always interlaced, or could it carry Prog Scan signals ?
    Does the Scart to VGA cable for a Z1 only carry interlaced.
  6. Kramer
    Kramer
    Scart RGB is, by nature, interlaced.
    Only component can (presently) carry progressive signals (well, also DVI - kind of "digital progressive", & VGA).
    VGA can carry different types of signal. RGBHV, YPbPr etc..
    Scart to VGA = interlaced (ie. RGB)
    :smoke:
  7. cyberheater
    cyberheater
    Apr 3, 2003
    3,200
    Scotland
    +178
    In other words. The Ae100 can only take progressive on component. It cannot accept RGB via VGA port because it cannot sync down to the required refresh rate.
    Are you winning mcaw?
  8. Kramer
    Kramer
    Small thread here with a link to an RGB/component convertor.
    Loads more too I'm sure :eek:
