AE100/Prov and RED smudging
Discussion in 'Projectors, Screens & Video Processors' started by lampshuk, May 21, 2003.
  1. lampshuk
    lampshuk
    I'm using a ProV tuner/doubler to drive the PC/RGB input of my AE100 and the video quality is in general excellent (subjectively better than using the S-Video straight from the DVD player into the PJ).
    The only niggle is that bright red often ends up "smudging" a bit. I've fiddled around with various saturation settings but reducing it snough to eliminate the smearing makes the picture look quite cold.
    Anybody got any suggestions? Would composite video give superior results?
    Lampsh.
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Lampshuk,
    If you do a search on "ProV" here on the forum, you'll unearth a thread with a discussion of settings for the ProV. I don't recall having a problem with colour reproduction from the ProV, I reckon that some more tweaking with the settings should see you right.
    All the best,
    Sean G.
  3. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Mmmmm I haven`t experienced this with my set up (Ae100 and Pro V.
    Have you tried adjusting the colours on both Pro v and the projector through same input?
    I cant think of any thing else unless its a fault somewhere, hope you sort it
