ae100/progscan....wow!!
Discussion in 'Projectors, Screens & Video Processors' started by codling, Apr 24, 2002.
  1. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    hi all,
    got my player back yesterday with the progscan board fitted.:D wot can i say ,the picture is fantastic.
    i thought interlaced was great.
    also got the code to activate pal progressive(thanks to a member of this forum),tried jurassic park 3.picture is superb.pity i only have a handful of pal discs:(.
    still havnt watched a movie on my pj(been nearly 3 months of bloody decorating:rolleyes: )should be done in about 2 weeks.then its movie heavan:D :D :D
    thanks carl
    p.s. anyone got any tips on drilling through wall tiles:confused: (just tiled the bathroom so dont want to crack any,).the old man reckons taping the tiles first,but he's a good wind up merchant(the old git).
  2. Timh
    Timh
    Sep 14, 2000
    5,224
    3
    3
    Altair-4
    +310
    Yes, progressive scan rocks :D
    Take it from your Dad, he knows what he is talking about.
  3. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    cheers tim
    i thought he was taking the pi$$:rolleyes:
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Use electrical tape on the tiles and a Tile bit for drilling.
  5. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    The code I take it was for the Arcam?
  6. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    General Skanky
    yes the code was for the arcam
    cheers carl
  7. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Masking or vinyl tape, a masonry bit and patience.. A really slow speed drill helps to start you off. If you need a big hole(over say, 6mm) start with a smaller one. You can lubricate with water, but I don't usually bother.
    You may have to use a fair bit of pressure to start it and the bit will still want to wander before it bites but I haven't cracked one yet :)
  8. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Sorry, last post completely OT.
    Progressive scan is the dogs cohones even better via the rgb but don't let that put you off.
  9. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    Dubbing Mixer
    i gather you dont use the hammer setting on the drill:confused:
    gonna put all the fittings up the weekend.
    god if i crack a tile ill cry my eyes out,its took me 3 days of blood,guts:mad: .if i have to look at another tile again ill go mad:eek:
    carl
  10. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Hi codling,
    NO! definitely not the hammer setting. Buy a new masonry bit, take it easy and you should be fine. The hard part is breaking through the glaze to start. Once you've done that it's easy. If you want to minimise the mess, get Mrs. codling (or other willing victim) to hold a hoover nozzle just under the bit. (With the hoover switched on!!!)
    Rob
  11. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    ill have the girlfriend just open her mouth within about a 50 foot radius,should do the trick:D
    thanks for the tips
    carl
  12. pinda
    pinda
    All my dvd's are pak...does that mean the arcam is the best dvd player for me?? if so..where did you purchase it from...how much?
    Pinda(victim of 2 duff pannys)
  13. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    pinda
    i got mine from gilson audio in middlesbrough.
    cost was £900 and £350 for the progressive scan upgrade.
    its expensive,but im glad i got it now.
    so if funds are there i would definatly recomend it.
    probably better going for the fjm dv27.for a couple of hundred quid more.
    while it was in for the upgrade i borrowed my old player back of the parents(sony dvp-s7000)which i thought was a great player.
    but the picture was very soft and blurry(i thought it was my replacement ae-100)it was quite a strain to my eyes,felt i couldnt focus the pj.
    when i finally got the arcam back the picture blew me away a absolute huge leap.
    cheers carl
  14. Timh
    Timh
    Sep 14, 2000
    5,224
    3
    3
    Altair-4
    +310
    In the past when drilling tiles, I have also scratched some of the glaze of first, this helps the drill bite into the tile.
  15. Dodgey
    Dodgey
    By far the easiest way is to use a tile bit. You can get one at b&Q for a couple of quid. They are designed for the job. Done loads in my bathroom. No problems
  16. Guest
    She had plenty of practice then?:eek:
  17. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
