ae100 or sanyo z1 or other?
Sly
went to sevenoaks today and the guy said that the new sanyo z1 was a good reliable alternative to the ae100.
has anyone out there seen it?
and is it any good?
and are there any other projectors coming out in the next few months that are worth hanging on for(ae200?).
also anyone know of a stockist brum area that can give comparisons of a few @ the 1500-2000 price bracket?
i think that will do to start the ball rolling:D !
thanks.
B
BLUE-DUSK
Looks like a good choice. I had a word with the Toshiba rep. about this matter and he recomends their TLP-MT7 as a quality solution. Can anyone confirm this?
:rolleyes:
Sly
i can confirm that it is twice the the price!
:eek:
Sly
Perfect for DVD and High definition TV veiwing
The Sanyo PLV-Z1's wide 16:9 ratio along with it's 1/4 high definition panels make it the perfect choice for viewing 16:9 widescreen DVD movies (480i, 480p)and HDTV format (720p, 1080i) format programs.
High quality images
A contrast ratio of 800:1 and a number of advanced features, including auto-grey scale and 10 bit gamma correction help the Sanyo PLV-Z1 produce incredibly lifelike images.
Whisper quiet fan
Using Sanyo's whisper quiet fan technology, the PLV-Z1 produces an amazing low noise level of just 29dBA in
black theatre mode.
Model No. PLV-Z1
Resolution One-Quarter HD (964x544)
LCD Panel System 0.7” TFT Poly x 3 (16:9)
No. of pixels 1,573,248 (524,416 x 3)
Projection lens Short Zoom; F2.03-2.34 / f0.83”-1.00”
Brightness 700 ANSI Lumens
Lens shift Manual; (Up/Down/Left/Right)
Up/down Left/right ratio Up/Down – 10:0-0:10, Left/Right – 7:3-3:7
Projection lamp 130W UHP
Contrast ratio 800:1 (full on/off)
Screen size 30”-200” diagonal
Throw distance 3.6’-19.7’
Colour system PAL/PAL-M/PAL-N/SECAM/NTSC/NTSC4.43
Input Terminals
D-Sub15
Component RCA x 3 (Y, Pb/Cb, Pr/Cr)
Composite RCA x 1
S-Video (mini-DIN 4-pin)
Data Compatibilty XGA, SVGA, VGA
Uniformity 90%
Operating noise 28dBA (Theater Black mode)
Dimensions (WxHxD) 13.1”x4.3”x9.7”
Sound output None
Power consumption 210W
Included Accessories Backlit I/R Wireless Remote Control
AC Power Supply Cord
Owner’s Manual
Composite Video Cable
2 “AA” Batterieis
sounds good!
Sly
PTAE100E
Home Cinema Projector
Panasonic's easy-to-use home theatre LCD projector embodies know-how nurtured in the business market and that actualises true performance at a popular price. This product makes powerful large-screen images enjoyable at short distances with the use of an short focal lens.
SPECIFICATION
Power supply
AC: 100 V - 240V, 50 Hz/60Hz
Power Consumption
180 W (0.7 W on standby)
LCD Panel
0.7 (diagonal) polysilicon TFT Wide LCD Panel (x3)
Pixels
1,240,000 pixels
Lens
Manual zoom (1 - 102)/focus lens F 2.0 - 2.3, f22.0mm - 26.2mm
Lamp
120UHM lamp
Brightness:
700 ANSI Lumens
Scanning Frequency for RGB signals
fH 30 kHz - 70 kHz, fv 50 Hz - 87 Hz
YPBPR signals
525i (480i), 625 i, 525p (480p), 750p(720p), 1125i(1080i)
Colour system
NTSC/NTSC4.43/PAL/PAL-M/PAL-N/SECAM
Projection Size
40 - 200 (16:9 Aspect ratio)
Throw distance
1.2m - 7.4m
Installation
Front/Rear/Ceiling/Desk
Audio
2 W (mono)
Input
VIDEO IN
S-Video: Mini DIN 4-pin
Video: RCA pin jack
Audio: RCA pin jack x 2 (L-R)
PC IN
RGB: D-sub HD 15-pin
Audio: Stereo mini Jack
Component IN
RCA pin jack x 3
Audio: RCA pin jacks x 2 (L-R)
Dimensions (W x H x D)
280mm (11) x 85mm (3-11/32)
x 242 mm (9-17/32) (included lens)
Weight
2.7Kg (6.0lbs)
Operating Environment
Temperature
0oC - 40oC (32oF - 104oF)
Humidity
20% - 80% (no condensation)
Supplied Accessories
AC cord (3m)
Carrying Bag
AV cable (3m)
Remote Control
Lens Cap
