AE100 or 200 for DVD?
Discussion in 'Projectors, Screens & Video Processors' started by richard plumb, Oct 22, 2003.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,478
    Windsor
    +1,046
    Can someone tell me if there is an actual improvement with the AE200 projector for DVD? (mostly region 1)
    Its 540 vertical resolution isn't much more than the AE100's 480 lines, but the AE100 matches the resolution of DVDs perfectly, whereas some scaling will be required in the projector on the AE200.
    I'm assuming even if you use a progressive scan DVD player it will only output 480p, so scaling is still required (HCPC not withstanding)
    Does anyone have any opinions as to whether it is a better projector? Does it matter as its cheaper in some places than the AE100?
    BTW, I don't really care, as I have an AE100 and won't upgrade until at least AE500/Z2 - I was just curious after seeing the specs.
