AE100 - new fault?
Discussion in 'Projectors, Screens & Video Processors' started by mca, Jul 14, 2003.
  1. mca
    mca
    May 7, 2003
    274
    +34
    Just got my AE100 from Komplettt and noticed a problem straight away. The very top part of the display has a darker blue/purple tinge and the bottom a yellow tinge. Most annoying when playing a 1.85:1 film or displaying Windows on the PC.
    There's some pictures here, here and here.
    (And before anyone asks - I'm projecting it onto a temporary surface until I get a proper screen, it's just sheets of white tractor feed printer paper but does the job.)
    It's there when I use s-video from my Tosh DVD player and the 15-pin d-sub analogue connection on my PC. Any thoughts? Is this a 'new' fault? I'll contact Komplett first and see what they say but otherwise Panasonic might know more.
    Otherwise I well impressed with the picture that is produced by the PC input. The s-video input leaves a bit to be desired.
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Mike,
    That doesn't look right at all - I'd get on to Komplett for an RMA and get them to send you another one. At a guess it doesn't look like a panel alignment problem - more like damage to the optics or a fault with the prism. One way or another, it shouldn't look like that "out of the box". I'd go for a replacement from Komplett rather than getting on to Panasonic.
    Hope you get sorted,
    Sean G.
  3. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    MCA,
    I have to admit when I read the thread title and then started reading your post, my first thought was that if you did a search on the forum you would find this isn't a 'new fault' (colour uniformity issue etc etc). I'm sorry for doubting you mate! :D I loaded up your pics and OMG, that is 'new'! :D I'd agree with Sean on all points. Thats nasty! I can't envisage you having any problems getting a new unit from either Komplett or Panasonic. Theres quite obviously something very wrong with your PJ and they'll probably sort you out no questions asked.
  4. mca
    mca
    May 7, 2003
    274
    +34
    Thanks all, just filled out the returns form over at Komplett. No doubt it'll be a while before I get another one :(
    It's a real shame because otherwise I'm really impressed with it.
