AE100 - making the image smaller
dUnKle
Have a make shift screen installed and the projector on a shelf at rear of the room
However restrictions have meant that even when I turn the lens zoom all the way down the image is still slightly too big
Its nothing major but it would be nice to have it that little bit smaller to make viewing more comfortable
Is there any way to do this without moving the PJ closer to the screen ?
Also, where can I get the cieling bracket from and how easy is it to install ?
dUnKle
I just wandered if there was any menu options on the PJ that would make the screen that little bit smaller.
Ill have to bring the screen that little bit closer
J
Jonny1973
Hi Duncan,
No, there are no options to make the image smaller other than the optical zoom lens (which you have already adjusted).
No projectors would have the feature you mention as it would waste loads of pixels.
The only options you have are
1) move the projector nearer the screen
2) move the screen nearer the projector
3) buy a projector with a longer throw.
dUnKle
Ill do a combo of both I think
Its not miles too big, just a little uncomfortable
Mr.D
I think you could use theatertek to zoom out from the screen a bit. You can map the image into the middle of the screen and surround it with a black border ( not done this myself but pretty sure you could do it I'll have a look) Course this will entail a loss of resolution so its not ideal.
