AE100 flicker
Discussion in 'Projectors, Screens & Video Processors' started by (GTV)Chris, Jun 11, 2002.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Has anyone experienced a flicker every 10 mins whilst displaying composite tv images?
    I don't notice it at all when displaying DVD?
    Also, When displaying my computer via VGA in the recommended screen resolution...I notice that the text is wishy washy in vertical strips...I have adjusted all the settings but no matter how I try I cant get the entire screen in focus...
    Anyone know what I'm doing wrong?
    Chris
  2. Guest
    re VGA, have you tried doing an Auto Setup in the position menu, usually sorts that out
    Andy
