ae100 discrete codes
I
itspman
I know this has been asked before but I can't find them any where.
I need disrete codes for the Panasonic PTAE100 projector, I have looked on remotecentral and the normal places but nobody seems to have one for the pronto or indeed any other universal remote, anybody help please.
Kind Regards
Adrian:)
Timh
Are you talking about the code's which will only switch on or off the AE100, if so it maybe a problem as the same code turns it on and off, as you know you press power once for on and twice for off. I have my system off button programmed to turn off the AE100, but if its already off it's a pain as it switches it on :(
I
itspman
thanks for the reply,
I am not to concerned about switching on/off it is really the input code to select say s-video or component, rather than having to cycle through them.
Adrian :p
Timh
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
