ae100 dead pixels
Discussion in 'Projectors, Screens & Video Processors' started by tal2, Apr 18, 2003.
  1. tal2
    tal2
    Hi folks
    Just got a AE100e from Techtronics and it has got 2 red and one green dead pixel
    How do I stand ??
    Is this under warrenty
    How long do I have to report said pixels ??
    I ve got a two year warrenty so .............................
    Tal
  2. dcullen302
    dcullen302
    If you get on to Techtronics, they'll probably get back to you with Panasonic's recommended dead pixel levels - if your amount of dead pixels falls within those levels there will probably be nothing considered wrong with your projector...
    From the following URL (nexnix's dead pixel policy page):
    http://www.shootandshow.co.uk/panasonic-deadpixel.htm
    "Panasonic Spec for dropped pixels:
    - Up to four blue is classed as acceptable anything over is replaced.
    - Up to one red is classed as acceptable anything over is replaced.
    - If you have one green it is unacceptable and will be replaced."
    I'm not 100% sure if this only refers to the new AE300 or if it is Panasonic's policy on all their projectors - if it is, you may be able to get it replaced seeing as you have 2 reds out.
    Check with Techtronics.
    On another note, I've read some about people paying nexnix for a dead pixel check and was wondering what happens if, after nexnix check a projector and it's free of dead pixels, one or two pixels go after you get it - do nexnix claim to replace a projector even if any dead pixels amount to less than Panasonic's recommended levels?
