AE100 Cutting Out
Discussion in 'Projectors, Screens & Video Processors' started by keelby1, Mar 22, 2005.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,174
    38
    Grimsby
    +11
    Bit old school this I Know, but my AE100 cuts out after about 15 seconds. When I press the power on, it starts up, then the fan cuts out and about a second later it goes back into standby. It wont restart until I disconnect the power and obviously reconnect only for the same thing to happen.
    Ive taken it to the local Panny dealership and they're saying its the air filter that needs changing. Ive tried to start it without the air filter and the same thing happens.
    Anyone had similar expierences?
    Is it the dreaded psu problem?
  2. ptek
    ptek
    If lamp starts normally then shuts down, probally lamp(can't maintain arc), if lamp flickers and does not start then probally ballast module, but can be either/or, only by replacing lamp either confirmed, but be assured, its not the air filter clogged!
  3. keelby1
    keelby1
    Dec 11, 2002
    1,174
    38
    Grimsby
    +11
    I've spoken to the panny dealership once again, and they cleaned the air filter, and tested it for over an hour with no problems.
    They ordered a new filter for me (16p) but I dont expect it to solve the problem. It looks like it could be replacement time, bearing in mind there a second hand AE300 for sale at £400
  4. Elite Dave
    Elite Dave
    Sounds like the lamp ballast at fault which requires repair.
    Dave
