AE100 + Avia + Terminator2 = perfection?
Discussion in 'Projectors, Screens & Video Processors' started by jumpt_upmunky, May 25, 2003.
  1. jumpt_upmunky
    jumpt_upmunky
    Jan 5, 2003
    186
    28
    Hove
    +29
    OK the dvd player (tosh 210e) is connected via component to the projector.
    Can I use the terminator disk to set up brightness and contrast because of the ntsc black level problem with the Avia disk.
    And then use the avia disk to basically set up everything else?
    or can I use the avia for everything because of the component connection?
    is this is a good idea?
    and what's the best way to configure a normal tv in conjunction with the dvd player (scart RGB)
    I've searched all the forums and too be honest I've made my head spin!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    Avia only sets up NTSC levels so depending on PJ settings as to whether its uses the same levels for NTSC and PAL or not.
  3. Kramer
    Kramer
    Not going to be much of a difference anyway (IMO).
    I feed my PJ via HCPC - pretty much negates the whole "NTSC v Pal" issue.
    I'd go with Avia - will be a big improvement.
  4. Captain chaos
    Captain chaos
    What is Avia?
  5. Kramer
    Kramer
    Avia :)
    Calibration disc.
  6. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,051
    48
    +92
    Does anyone know where i can get the stuff used for the Saturation and Hue (colour and tint) setup?
    the Blue filter is what i need and i also need Red and Green filters for the Colour Decoder Check
    Where should i be going and what should i be asking for??
  7. Messiah
    Messiah
    Apr 22, 2002
    7,595
    +338
    You get the red, green and blue filters with Avia. See if Piero has nay left in the Power Buy forum.
  8. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,051
    48
    +92
    Mines rented so i got nothing with it
  9. cyberheater
    cyberheater
    Apr 3, 2003
    3,206
    Scotland
    +178
    Where did you rent AVIA?
  10. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,051
    48
    +92
    a local shop around here
