ae100 and screen
Discussion in 'Projectors, Screens & Video Processors' started by dexter, Jul 7, 2003.
  1. dexter
    dexter
    Jan 27, 2002
    214
    i need to buy a screen for use with the ae100 - i/m looking at the draper luma and the projecta procinema (7' 16:9models) - anybody got either of these? which suffers least from the dreaded "curl/ rippling"?
  2. dexter
    dexter
    Jan 27, 2002
    214
    ooops! forgot to add that i have also seen a similar type of screen made by a company called "grandview" - so that is three screens that i am confused about!
  3. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    I've got an 8ft Projecta Procinema screen...no curling/rippling so far that I can detect.
  4. Kramer
    Kramer
    Yep, recommend the Projecta Procinema screens - extra black drop included, helps with optimum viewing height.
    :smoke:
  5. Jonny1973
    Jonny1973
    I have a Da-lite Model B (£212) which suffers from the ripping problem but don't they all the cheaper ones?
    I know you can buy tensioned screens but they are much more expensive.
