Before you tie me up and whip me for not searching the forums (which i did) I can't seem to get my PC to use the full area of the pj image. It is confirmed that PJ is WIDE 480 mode via options I think my resolution doesnt quite switch correctly as my desktop appears about 5% short in the verticle area on both top and bottom. I can see the PJ projecting grey/black there so I know that space is available somehow. I did get to one point where the desktop area on the PJ display scrolled when i moved the mouse to the edges of the screen and no idea why it did this. Im using a Radion 9700 Pro Anybody else have a similar issue with a Radion 9700 Pro and Powerstrip? Cheers Anim
Anim, The search function is still your friend..................... check this out . You just need to check that your PC thinks it's addressing a widescreen monitor.... lots of details in the link. Sean G.
