Anim
Hi all
I finally bought a new pc and setup my old one as a HCPC.
Couple of questions.
1.
Using powerstrip and the timings found on these boards i've managed to setup both 480 wide and 720 wide.
480 Wide is so crystal clear that it makes 720 look unusable. I get aliasing on desktop text in 720 WIDE whereas 480 WIDE is clear as day, is that expected in the higher resolution or is there some settings I need to play with to get the same clarity?
2.
I use a Pinnacle PCTV Rave card (had to flash my bios to get rid of lots of green noise) which runs great now. DScaler works fine too. The only thing that I havent sussed out yet is how to capture as MPEG2 as it is greyed out in PC Vision. Is this a limit of the card or the software?
3. What filters and deinterlacing options to people use in DScaler for watching SKY tv?
4. Anybody know if I can get a digital output from a Sonicfury sound card into an Optical/Coaxal input on the Scan 6 speaker Amp.
Thanks all
Anim
HCPC
Athlon 1800 XP
GeForce 4 Ti 4200
512 MB Ram
30 Gig HD
Pinnacle PCTV Rave (TV Tuner)
Sonic Fury 6ch sound card
Broadband Connection via home lan (yea baby!!)
1.
2.
Thanks all
Anim
HCPC
Athlon 1800 XP
GeForce 4 Ti 4200
512 MB Ram
30 Gig HD
