AE100 and diagonal lines, help!
Discussion in 'Projectors, Screens & Video Processors' started by mandlebrot, Mar 2, 2003.
  1. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I have just become an AE100 owner and whilst watching through S-Video (connected directly form my Toshiba 220) I get fine diagonal lines sweeping across the screen please help.
    I thought that this could be some form of electrical interference so I put ferrite rings on each end of cable but lines are still there. Does anyone else have the same problem or had the problem and managed to cure it?:confused: Please tell me its not a fault of the PJ.
    I am going to get component leads when I can afford it but it will take me a few weeks to save up after just paying out for the PJ, hope component doesn't have the same problem.
    Anyway S-video is the best connection I can afford at the moment and these diagonal lines are driving me mad:mad:, so any help would be appreciated.;)
  2. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Your PJ is not faulty, its just the limitations of s-video, this is the reason I upgraded to a componant player, it really doe's make a differance.
    I found that the diagonal lines looked worse on strong colours, like Red. Try turning the sharpness down, I found this helped a small amount.
    I purchased my Van Damme componant cable's from www.tmfsolutions.co.uk I payed about £45 for 10 metre cables, cheap but good quality. You have to email for a quote as they do not have online purchasing, they can be a bit slow though.
  3. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Mandlebrot,
    Just for an experiment - try hooking up to the AE100 component input using regular interconnects - you know, the standard red, white and yellow ones which came with the AE100 - provided you can place your DVD player close enough to the PJ. The picture via component is actually very rich - andI just tried with long interconnects just to see what its like - with proper component cables it should be fine.
    All the best,
    Sean G.
  4. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Thks to both of you for the info:) I feel a bit better now:D
    Dam just checked out www.tmfsolutions.co.uk and they have put the 10 metre cable up to £54.26 plus delivery:(
  5. mole
    mole
    Try Home Cinema series from www.lektropacks.com
    10 m £33 + £3 delivery
    Regards
    mole
  6. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I actually fancy the Silverscreen version from them at £45, its not available for a few weeks which will give me time to save up for it;)
  7. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Poorly shielded s-video cables suffer from interference which normally manifests itself in the form of diagonal lines right across the picture. Good quality ones don't.
