ae evo compact sub
Discussion in 'Subwoofers' started by jace22, May 3, 2005.
  1. jace22
    jace22
    Mar 2, 2005
    442
    +9
    hi
    Wondering if anyone can help i have the above sub. The problem is that i find i have to turn it up high on the volume and crossover knobs to get the benefit on the movie side of things, but if i play any music it s way to high at those settings can anybody help
    i wish had bought a different sub reading on here but thats what ive got so itll be a while before funds allow for any upgrades
    sytem is as follows
    sp 4805
    beamax screen
    denon avr 2105
    pioneer 575
    ae evo 3 speaker pack
    thanks in advance
  2. Mroizouk
    Mroizouk
    Jan 11, 2005
    336
    London
    don't worry about having to use different settings for music and movies, this is quite common. most people would select higher crossover and gain settings for films.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Hi Jace
    Have you got a trim(bass managment) on your av receiver,On my old nad receiver i could alter the subs gain by lowering it on the remote a few db when listening to music then raising it when watching movies.
    You should be able to do this if you can do a speaker test on your remote you can lower the subs output on that when listening to music then put it back up afterwards. On every sub ive owned the settings have been lower on the sub when music listening.
    Cheers Gonzo. :)
  4. jace22
    jace22
    Mar 2, 2005
    442
    +9
    thanks guys didnt think of the remote option sure beats the alternative way
