AE EVO 3a questions
Discussion in 'Home Cinema Speakers' started by MR2Harvey, Nov 10, 2003.
  1. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    462
    +6
    Silly question but I have just measured how much speaker cable I need fore my system, then I suddendly thought.....
    How do you connect the Sub Woofer, I'm thinking of getting the AE EVO Sub, will I need speaker cable or do I connect using a phono cable?
    Any recommendations?
    Harvey
  2. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    462
    +6
    Right just measure how much speaker cable I need...too much > 20 meters.
    What thoughts have you got on speaker cables?
    I'm thinking of getting a NAD T752 Receiver and the Acoustic Energy EVO 3A speaker system.
    I was wondering about the QED Silver speaker cable. It's been a very long time since I last bought speaker cable (Naim NACA4 i think) what is considered good these days?
    Oh and then there's the Banana plugs and with a 5 speaker system I will need 20 of the things and they are quite expensive, any thoughts on what I need would be appreciated.
    Harvey
  3. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    462
    +6
    I'm thinging of 2 speaker systems:-
    1. Acoustic Energy EVO 3A
    2. Monitor Audio Bronze B4 AV 5.1 Speaker System
    Both similar price £700 to £750 depending on where bought.
    I want good stereo fronts and well intergrated surround sound.
    Which one should I get?
    Harvey
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Phono cable, for AV. Speaker cable for stereo.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dont bother with banana plugs unless you are moving your system a lot, silver QED is great for fronts but unecessary for rears.
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Or if you have a decent sub you can run it from the speaker outputs and thus get it to blend in with your main speakers better. I would advise getting a subwoofer from a company that specialises in them. Nothing against Acoustic Energy as a speaker manufacturer, I have their AE1 Mk3 reference monitors, but they make lousy subs, as do most mainstream speaker manufacturers.
  7. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    462
    +6
    Thanks,
    I have bought the QED silver for all 4 speakers, had to do it all in a rush as I am planning on having they hidden under the floor and I'm having a new floor put down tomorrow!
    As for the Banana plugs, I take it they are just a more convienent method of fixing, not actually better sound quality? Otherwise I need 20 of the damn things and that adds up to quiet a lot of money for decent ones.
    Harvey
  8. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    462
    +6
    I need to decide what height to fix my rear speakers to the wall. I am going to buy an AE EVO 3a system, this comes with 2 compact rear speakers with wall brackets. What height is deemed to be best? These speakers will have to be on the side walls facing in as I have to have the sofa touching the wall.
    Thanks for any advise
    Harvey
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    convienient only, adds extra joint and all issues with them into equation.
