AE Aego p5 Subwoofer broken - replace?
theclaretvillai
My subwoofer seems to be kaput - intermittent output of bass - sometimes can get it to work for a while by pressing the back of the subwoofer.
So do I try to get it fixed (where?)
buy another of the same subwoofer (from where?)
buy a different subwoofer (which? from where?) and reuse the 5 satellites and decoder.
Thx in advance for any help.
Dfour
What about emailing AE customer services and see what they can come up with.
Bassbin
I've got a P5 set in white from which I'm only using the proc and sats so would be happy to sell the sub on. I only used it for a week or two when I first got the set to try it out. It works fine but I did notice a hum coming from it which I think is a fairly common complaint about these units. If you're interested then put a wanted ad up and I'll respond to it. Would be looking for £40 collected from Leicester or £50 including delivery.
