Ae Aego 5 Mk Ii
Discussion in 'Home Cinema Speakers' started by wyzecoms, Apr 19, 2005.
  1. wyzecoms
    wyzecoms
    Hi All,
    Newbie question. I'm in the process of setting up my new Aego 5 MkII's. However I have a noise problem with my Rear Left speaker. Basically there's a much louder "hissing" noise coming out of this speaker compared to any of the other speakers. If I take one of the other speakers, plus cable and connect it to the rear speaker plug on the back of the Sub I get the same problem. This "hissing" noise appears as soon as I turn the whole system on. It's always there even if I change the input device to CD or DVD it makes no difference. Any ideas? :lease:
  2. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    Have you got that speaker turns up compared to all the others in the speaker setup menu?
    Regards
  3. john<|>nhoj
    john<|>nhoj
    If it is just the speaker cable and speaker that you swapped, it could still be lead from the pre-amp bit to the amp in the sub. Swap the leads from the pre-amp so the rears are reversed.
    If the same thing happens on the rear left as before it is in the active amp in the 2.1 part.
    If the speakers have reversed and the hissing is now on the right... then it is either cables or the pre-amp.
    Hope you get to the bottom of the problem...
    PS are they any good ? Thinking of these for rears in my av system.
  4. john<|>nhoj
    john<|>nhoj
