AE AEGIS EVO - HF or LF?
Discussion in 'Home Cinema Speakers' started by mattoneill, Sep 16, 2007.
  1. mattoneill
    mattoneill
    Oct 23, 2004
    40
    Doing a simple wiring job onsome AE AEGIS EVO, should i be plugging the speaker cable into HF or LF? im not bi-wiring. also, should i leave the plate that connects the HF and LF connections?
    thanks for your help
    matt
  2. anth1e
    anth1e
    Jul 7, 2007
    165
    +6
    i think its the lf you use, what i do know is that if your not bi wiring then you leave the plates there
  3. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    If Bi-wiring or Bi-amping, you'd remove the joining plates and have one amplifier(etc) to LF and one to HF.
    In your situation, leave the links in and connect to either, the difference would be so neglibable as to make no discernable differnce (unless you had low-quality linking plates or made from some weird material etc).
    On my Evos, I was using the LF posts as they were closer to the floor and therefore a little tidier etc.
    Hope that helps.
    Dan.
  4. mattoneill
    mattoneill
    Oct 23, 2004
    40
    will do - thank you for your help :)
