AE-700 with none prog scan dvd player
Discussion in 'Projectors, Screens & Video Processors' started by Evil Desires, Oct 26, 2004.
  1. Evil Desires
    Evil Desires
    Hi all,
    Ive just bought a panny AE-700 and as its a prog scan pj does this mean if my dvd player is not the pj will convert the source into prog scan?
    or am i best buying a prog scan dvd player for higher pic quality?
  2. Kramer
    Kramer
    Yes, it will "deinterlace" an interlaced signal as all fixed panel PJs display progressively scanned images.
    Whether a progressive scan enabled DVD player will produce better results is down to the player & whether it deinterlaces better than the PJ's own deinterlacer.
    :smoke:
    ......lot of deinterlacers in there.....:)
  3. Tup
    Tup
    Actually, from what I have read on projector central...it looks like many projectors do better with an interlaced signal.
  4. Evil Desires
    Evil Desires
    thanx for the replies guys looks like i'll be savein a few £££
  5. jamesgrahamuk
    jamesgrahamuk
    I was wondering the same thing myself. I have an early model of the Pioneer 757ai which has PAL progressive disabled (you have to pay £90 to Pioneer to get it enabled - bloody cheek!) and I am not sure if it will be worth it.
    I would assume that the deinterlacer in the Pioneer DVD player would be better than in the Panasonic AE700 (which I'm still waiting for) - but how much better? Is it worth £90 and letting some engineer get his grubby paws on it?
