AE 1000 screen contrast changing ???
Discussion in 'Projectors, Screens & Video Processors' started by BISHI, Jun 14, 2009.
  1. BISHI
    BISHI
    Mar 29, 2007
    9,753
    Leamington Spa
    +1,190
    Have notuced recently that the picture contrast goes up and down, almost like a very slow flicker, is this a bulb problem or a problem with the iris. I have 1000 hours of use on economy bulb setting . Any ideas fellas ??
  2. scumball
    scumball
    Jan 12, 2004
    6,511
    Harrow - London
    +449
    Had this on my AE700 - it was a dodgy bulb...
  3. BISHI
    BISHI
    Mar 29, 2007
    9,753
    Leamington Spa
    +1,190
    Turned the iris off.....and it still does it. You're probably right. Could this be dangerous for the PJ if I don't change it soon or should it be ok for a while..Bit skint at the moment so can't really afford a new bulb....:(
  4. scumball
    scumball
    Jan 12, 2004
    6,511
    Harrow - London
    +449
    Mine was like this for a couple of months until I bought a new bulb from PriceJapan.
    One thing I found was that when on high lamp and high fan power it happened less - then in the service menu I turned the fan to full mode and that pretty much stopped it - but it sounded like a jet taking off so you have to crank the volume up ;)
  5. BISHI
    BISHI
    Mar 29, 2007
    9,753
    Leamington Spa
    +1,190
    Cheers fella, if it gets worse I'll give that a go :smashin:
