AE-100. Where can I buy in HNKG?
Discussion in 'Projectors, Screens & Video Processors' started by Lito, Mar 13, 2002.
  1. Lito
    Lito
    How much and where can I buy it in Hnkg? Can anyone suggest a reputable dealer? TIA
    Lito
  2. dancer199
    dancer199
    try any of the shops on Nathan road.
    If you dont know where it is any taxi driver will take you to it (it will take you about 2 hrs to walk the length of it, its that long)
    The majority of them sell hi fi gear, if they dont have the panny they will be able to point you to a dealer, most of the dealers are really good
  3. Guest
    When I was in HK a while ago, there was a new store that opened in the road opposite HMV in Kowloon that has lots of plasma tv's in the window. Worth a try! Just follow the road up to the end ( I think it's near the side of the Mosque type building if that's any use to you?). Other than that, e-mail panasonic and ask for local dealers.
    Cheers,
    Dean .
