AE 100 Vs HS1
Discussion in 'Projectors, Screens & Video Processors' started by benji_m, Apr 15, 2002.
  1. benji_m
    benji_m
    Apr 14, 2002
    708
    Lancashire
    +6
    I want to buy either the AE 100 panasonic or the HS1 Sony, I have seen the Sony working in room lit by bright sunlight and it was still watchable! Anybody directly compared the two? The AE100's are like golddust at the moment so I may get impatient and go for the Sony, but of course regret it later!
  2. Guest
    Can anyone please post screenshots of the HS1 too?
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    personally I preferred the AE100. I found it had a much more watchable image. I found the HS1 a little tiring to watch.
    But the HS1 was demoed in a dealer, and the AE100 was at home, so they weren't in exactly the same situation. Having said that :), the HS1 was in a light controlled room with proper screen, and I demoed the AE100 at home projecting onto some white card I had lying around. And it still looked better to me.
    I'd try and see both in action though, because some people are very happy with their HS1s.
