AE 100 Thought
Discussion in 'Projectors, Screens & Video Processors' started by Chaos Star, Nov 4, 2003.
  1. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Just read this on Home Cinema newsgroup
    "It does seem like the AE100 can be sensitive to not being shutdown
    properly but on the bright side when they repair them they upgrade
    capacitors in the psu section and this should make it more reliable
    from them on. The ae100 has a universal power supply but it seems the
    standard capacitors in the psu don't cope too well with uk voltages
    once upgraded its ok. The ae100 doesn't seem to have the same
    reliability problems in lower voltage countries."
    When I bought my AE100, it came with a euro power cable. If this was used with an adapter could this reduce the risk of the PSU goig BOOM?
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    what sort of an adaptor? If you mean a 2 to 3 pin with nothing in between, i wouldnt see it making any difference. Its still the same voltage afterall
    ad
  3. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    I was thinking along the lines of an adapter that would drop the voltage, but Im unsure if this is possible and the costs involved
  4. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    oh, a transformer...... it is quite possible that would work
    ad
